Installing sleeves
Posted by Mike on March 15, 2002 at 17:34:22 from (205.188.192.186):
Im rebuilding the engine in my A. Is there a good way of installing wet sleeves so they do not leak water past the O rings? Should you put some kind of sealer in the O ring groove? Also what should you lube the sleeve with before you slide it in the block. Thanks Mike
Post A Followup
: Re: Installing sleeves
