Farmall Tractors Discussion Board
Re: voltage regulator
Posted by ltf in nc on August 03, 1999 at 07:08:08 from (206.228.213.48):
In Reply to: voltage regulator posted by larry ramsey on August 03, 1999 at 05:44:09:
A generic 12 volt regulator from NAPA should work. Make certain that you read the identifiction on the terminals and move BAT wires from one to BAT terminal of the other. Do the same for the ALT/GEN and the FLD. There should be a spec. sheet in the box for polarizing the regulator. This is a 12 volt Negative ground on this tractor, right?
Post a Followup
: Re: Re: voltage regulator
