Re: Re: Re: Bob M, other electrical guys...
Posted by Bob M on March 16, 2002 at 17:34:13 from (66.66.72.246):
In Reply to: Re: Re: Bob M, other electrical guys... posted by Steven@nd on March 16, 2002 at 11:13:44:
third party image
Steve -
The diagram above shows a typical DPDT switch setup. To operate your Hobbs meter wire the "+" on the Hobbs in place of the warning light in the diagram, and wire the magneto kill terminal exactly as shown.
A DPDT (double pole double throw) switch is two electrically isolated switches in a single unit and which operate in unison. Radio Shack stocks several different types of DPDT switches which will work. Make sure you get a 2-position switch - NOT a 3-position (or "center off') switch.
Hope this helps! ...Bob M
Note - if the wiring diagram doesn't display, here is the URL: http://albums.photo.epson.com/j/View?u=4001561&a=30065733&p=60405158&Sequence=0&res=high
Post A Followup
: Re: Re: Re: Re: Bob M, other electrical guys...
