Farmall Tractors Discussion Board
Re: What is an overrunning clutch?
Posted by Bob M on August 03, 1999 at 08:27:52 from (192.232.120.194):
In Reply to: What is an overrunning clutch? posted by Ryan on August 03, 1999 at 07:27:44:
Overrunning clutch permits the tractor PTO to drive an implement (typically a bush hog), but prevents momentum from a coasting implement from "driving" the tractor when the clutch is depressed. A tractor with ground (non-live) PTO and working a high-momentum implement without an OR clutch is a terrifying combination, should you need to stop in a hurry...
OR clutch fits between the PTO stub shaft on the tractor and the driven implement. For $75 or so, it's a worthwhile investment.
Post a Followup
: Re: Re: What is an overrunning clutch?
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
