Re: Will a WD9 belt pulley fit a W400 Diesel?????
Posted by Charlie on March 17, 2002 at 12:22:59 from (209.130.138.108):
In Reply to: Will a WD9 belt pulley fit a W400 Diesel????? posted by Hank on March 16, 2002 at 23:04:02:
I don't know for sure but I would guess the W9 assembly wouldn't fit. My Dad tried to put the pully assembly from a H onto a 350 with a TA one time and it wouldn't work (deal said it should work but I think the TA was the reason it didn't). If your tractor doesn't have a TA a pully asembly from a M might work but if you have a W series it might not either. Sorry I can't say for sure.
Post A Followup
: Re: Re: Will a WD9 belt pulley fit a W400 Diesel?????
