Re: Re: Re: reassembling Cub after trans repair
Posted by Bus Driver on March 18, 2002 at 04:26:37 from (65.165.153.60):
In Reply to: Re: Re: reassembling Cub after trans repair posted by Glen on March 17, 2002 at 20:05:02:
Glen, given the natural mechanical ability that you have-as demonstrated by the repairs thus far, this will be an easy job. The clutch should already be aligned perfectly. The back of the crankshaft has a blind hole and there is a bushing in this hole. Make sure the bushing is clean with no trash limiting the depth of it. Use a bit of good grease to lube the inside of the bushing. Then just make sure that no side pressure is placed on the shaft when reassembling. All should be well. How is the clutch release bearing?
Post A Followup
: Re: Re: Re: Re: reassembling Cub after trans repair
