Re: How to use TA?
Posted by Wildbill on March 18, 2002 at 11:28:35 from (206.222.209.88):
In Reply to: How to use TA? posted by Chris B. on March 18, 2002 at 08:39:57:
The whine can get real bad if you do not check the oil level in the PTO unit. There is a check plug on the left side of the unit that is a little hard to get to and easy to forget about. That may also account for some excess heat in that area.
Post A Followup
: Re: Re: How to use TA?
