Re: Farmall M clutch
Posted by Mark on March 19, 2002 at 09:57:53 from (198.109.223.251):
In Reply to: Farmall M clutch posted by redrev on March 19, 2002 at 07:20:20:
The only surprise you will find after removing the hydraulic (belly) pump is the 'throw out' bearing carrier assembly. It is a pot-metal sleeve that is bolted with two cap screws and provides support for the 'throw out' bearing. This sleeve must be removed to allow the 'throw out' bearing to come out. Once that is done, you will also notice a coupling that connects the transmission input shaft to the splined shaft in the clutch itself. The coupling is easy enough to understand once you see it. Just remove the coupling and the splined shaft can then be removed from the pilot bearing in the flywheel. Next remove the pressure plate and the clutch disk will drop into your hands. I recommend using the splined shaft to align the clutch disk and pressure plate with the flywheel when reassembling the clutch. Reassemble the rest in reverse order and the job is done. There isn't exactly alot of room to do the job, but it's better than splitting the tractor in two. (I have done this)
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
