Re: international 3444 tractor and backhoe diesel
Posted by RPM on March 19, 2002 at 13:13:48 from (63.110.182.225):
In Reply to: international 3444 tractor and backhoe diesel posted by joe on March 15, 2002 at 15:33:44:
This tractor evolved from 3414, has a different engine, not too common in ag use, was only sold through Construction Dealers (CE), had a Hydra-Shuttle transmission that was not used on AG line, special frame & loader made as intregal unit. You will probably have to check with a Komatsu/Dresser Dealer.
Post A Followup
: Re: Re: international 3444 tractor and backhoe diesel
