Re: Coil problems
Posted by Honkey on March 20, 2002 at 17:29:44 from (64.68.163.28):
In Reply to: Coil problems posted by Justin on March 20, 2002 at 16:17:11:
Hi Justin,
What model are you working on? Is it positive or negative ground? If your points are closed and your key is on, the coil will get hot. How many volts do you have a the points? With the resistor you should have around 6 volts. This reduction helps keep your points from getting burnt. Get a volt meter, check it out and get back to us.
Also check your volts at the points when you are cranking your engine, it should be 12V if you have a 2 pole solenoid on your starter.
Post A Followup
: Re: Re: Coil problems
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
