Re: Farmall M Oil Change
Posted by Michael Soldan on March 21, 2002 at 15:23:48 from (216.46.130.107):
In Reply to: Farmall M Oil Change posted by vic on March 21, 2002 at 13:06:18:
Vic if you need to drain the trans the drain plug is a pipe plug style located under the power take off. Your engine oil check is via the two taps on the side of the oil pan. Open the top tap to see if oil is to that level, add slowly until it begins to run out...the bottom tap is used likewise for the lowest level so your operating range is the level between high and low. Check that trans fluid.. if it is the colour of cardboard you have water in the trans and it is likely if it hasn't been changed in recent years. If the tractor has sat a long time the water might run out first but if you have been using the tractor the oil and water are mixed together giving that cardboard colour...drain and replace..good luck from Mike in Exeter Ontario
Post A Followup
: Re: Re: Farmall M Oil Change
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
