Farmall Tractors Discussion Board
Re: f20 serial # and value
Posted by Farmall Gray on August 03, 1999 at 19:16:59 from (205.188.193.156):
In Reply to: f20 serial # and value posted by david b. hunter on August 03, 1999 at 11:23:12:
The number you have given is not the serial #.
It is the part # of the rear axle housing. The
serial # is stamped on the top of the left frame
rail probably near the clutch housing. It also was on the serial # plate on the tool box if it is still on the tractor. It seems very common for Regular, F-20 and F-30 to be missing the plate.
The engine serial # should be stamped on a pad on the left side of the block near the back below the manifold. The engine serial # is not always the same as the tractor serial # but they are usually close enough to give you the right year.
The serial # should start with FA or T. As for value, It is hard to say because 1 guy's idea
of a restoration is another guy's idea of a quickie repaint. On an F-20, To do a first class restoration using authentic parts and fixing everything that is broken or worn out would cost
several times what the tractor could be sold for.
I'm finding this out as I'm in the process of restoring one myself. Don't get me wrong, because
I am happy to be doing it. I'm just trying to point out that F-20s are not that valuable-restored or not. I paid $700. for mine from a good friend in running condition with decent paint. hope this helps.
Post a Followup
: Re: Re: f20 serial # and value
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
