Re: Super A Carb Kit Cost?
Posted by Bama Binder on March 22, 2002 at 14:10:04 from (199.97.118.200):
In Reply to: Super A Carb Kit Cost? posted by SAm in NS on March 22, 2002 at 13:08:44:
My experience is limited to a Cub and Super H carbs, but I'll help you where I can. I used a basic kit from TISCO on each. Carbs are really simple to overhaul.
These provide the basic wear items and gaskets. If the rest of the parts are in good condition, the basic kit is what I would recommend. If there are specific parts you need beyond that, call your friendly IH dealer.
The really important thing to do is get everything CLEAN and make sure all passages are open. If there is heavy dirt and varnish, I would take it apart and soak everthing in laquer thinner. That will just leave the dirt to contend with, but it will just scrape off. I used a Dremel tool with wire brushes to clean it with. Ended up looing like new. They both run great also.
Best of luck...BB
Post A Followup
: Re: Re: Super A Carb Kit Cost?
