Re: STEERING SHAFT SEAL
Posted by Haas on March 22, 2002 at 17:28:50 from (129.37.117.161):
In Reply to: STEERING SHAFT SEAL posted by DAVE S. on March 21, 2002 at 17:15:01:
The steering wheel shaft and the worm gear is all one piece, so the only way you can replace the steering shaft seal if from the steering wheel end. YOu have to remove the steering wheel to do it. Then, as the others said, you can take the big plug out of the front of the steering box, hold the front wheels, and the worm gear/steering shaft will screw right out. When it's out, you can then easily pop out the old seal and press in a new one. While you have the shaft out, check the ball bearing on the end for wear. If it has any play at all, replace it. (Costs less than $10 for a new bearing). All you have to do to replace it is remove the cotter pin from the castle nut, unscrew the nut and slide the old bearing off and the new one on. Getting rid of play in that bearing will help tighten up your steering system. Make sure all the rough spots are off the steering wheel shaft before you slide it back in to avoid damage to the new seal.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
