Re: Farmall H with a 3 pt a Loader?
Posted by John Nelson on March 22, 2002 at 18:52:27 from (12.222.104.64):
In Reply to: Farmall H with a 3 pt a Loader? posted by Jim on March 22, 2002 at 16:20:28:
Think of the hydraulic system as you would the water pipes in the barn. They all work on the same principle. You will need a gate valve (this is a valve that has one input and two outputs) for the pressure side of your hydraulics... just as you would use a gate valve to divert water from one source to two different outlets. This is much easier with single action hydraulics than if you had dual action. First, remove the hydraulic coupler for the loader and attach the inlet of the gate valve to this point. Next, attach a coupler to one of the outlets in the gate valve, and reattach it to the loader. If you did nothing else now... and you had the gate valve set for the loader... everything would work the same as before. Now, attach a second coupler to the other output from the gate valve. Use this for the other implements you want to use that need hydraulics. When you need the others... put the gate valve so that it supplies oil to the other implements (rams etc..) and when you need to use the loader change the gate valve back to the loader. Even if you system leaks a little...and most do... you can always change the gate valve back to supporting the loader and raise it back up... then change it back to the other implement you need. Good Luck Write if you have questions.
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
