Re: need help (hydraulic on a smta)
Posted by rich on March 22, 2002 at 19:59:52 from (206.9.239.130):
In Reply to: need help (hydraulic on a smta) posted by Bill l on March 22, 2002 at 16:13:36:
first of all , the SMTA has one or two rods. I assume you have 2 rods. If it has a factory double acting valve, the double acting valve which should be installed under the right fuel tank needs to be locked in the forward position. this forces the oil to go to single acting liftall valve and reserviour. If you have a hydraulic bucket . this will not work. If you want to install a valve you need to plumb it in the high pressure hose that goes from the pump near the distributor to the reserviour. the high pressure hose is the smaller one. The valve which could be a grieson or cross needs to have a relief of no higher than 1000 psi. If it is higher you run the risk of shearing a key on the distributor. the hose from the distributor goes into the inlet side of the added valve. from this valve, the hose then goes back to the reserviour. and the large hose which is the return hose does just that ,returns the oil from the reserviour to the pump . with this system you can use both the liftall valve and the added valve.No need to have one valve locked. the IHC 2 way valve does not have a relief but uses the single acting relief because when the 2 way vlave is used the single acting is locked in the up position. by the way the hydraulic pump could be warn because there was no filter usedon therse tractors.You may want to check pressure
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
