Re: C or Super C
Posted by Mark Peters on March 09, 2009 at 17:44:40 from (66.222.6.49):
In Reply to: C or Super C posted by jc newton on March 09, 2009 at 17:33:39:
If it has serial # tag on, the C has a 5 digit serial # and the SC has a 6 digit #. If no tag, then look at the clutch/brake pedals. The C`s are straight and the SC`s curve back toward the operator.The C has band brakes which have a sheet metal cover bolted on the outside of brake housing. The SC has disk brakes which have a cast iron brake housing.C has a 15" steering wheel and a SC has an 18" .You can put a 18" steering wheel on a straight C but it leaves very little room between the bottom of wheel and the seat.They changed the angle of the steering shaft on the SC to accomodate the larger wheel.
This post was edited by Mark Peters at 17:54:13 03/09/09.
