Re: 9 bolt rear hub
Posted by Dan on March 23, 2002 at 19:44:41 from (12.18.158.25):
In Reply to: 9 bolt rear hub posted by Texas Red on March 23, 2002 at 15:39:55:
If the 9 bolt hubs are held on by U bolts I would suspect they are from a different brand of tractor. I used a 9 bolt hub off of a Massy Harris that had the same axle diameter as my SMTA. It has only 1 keyway vs 2 for the IH. It was a 1/2 incl keway whereas the IH was tapered. I got some step key stock and worked it out. I did it because I had some wheels and tires I got with the hubs for free. I think Oliver had hubs with u bolts holding them on.
Post A Followup
: Re: Re: 9 bolt rear hub
