Re: F-14 Crankcase cover oil seal
Posted by F14 on March 25, 2002 at 04:26:18 from (216.204.135.247):
In Reply to: F-14 Crankcase cover oil seal posted by John on March 24, 2002 at 18:18:48:
Crankcase cover? Do you by chance mean the oil pan? The only felt in that neighborhood is the rear main seal on the crankshaft. If that's what you're talking about, I'm pretty sure you can do it with the engine in the tractor. Take off the oil pan, take off the joint between the clutch and the transmission, drop the bellhousing, clutch and flywheel. (This is where the "pretty sure" comes in. I'm not absolutely positive there will be room between the input shaft to the trans and the clutch assembly to get the bellhousing out.) There is a two-piece aluminum retainer bolted to the back of the block casting that holds the felt seal. Unbolt that and pull the upper and lower felts out and replace them. NAPA stocks the gasket kit, believe it or not.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
