Re: F-14 Crankcase cover oil seal
Posted by Tim Wafer on March 25, 2002 at 18:16:16 from (63.15.154.235):
In Reply to: F-14 Crankcase cover oil seal posted by John on March 24, 2002 at 18:18:48:
Are you talking about the front crankcase cover and the crank seal? If so remove the cover and the seal goes in from the back.
Tim
Post A Followup
: Re: Re: F-14 Crankcase cover oil seal
