Re: saginaw hitch hydraulic lines
Posted by Ron on March 26, 2002 at 01:56:45 from (216.231.138.30):
In Reply to: saginaw hitch hydraulic lines posted by Ron on March 25, 2002 at 02:41:14:
I went out yesterday and had the hydraulic lines made for the hitch. The pressure line comes from the T outlet on the right of the hydraulic "box" (under the gas tank). This goes back to another T between the two cylinders, and then two lines to the bottom ports of the cylinders. The top ports got breathers. The local IH-Case dealer made them up from 3/4 hose and put on swivel connectors for a total of $88. The arms lift, but slowly, so I think I'll be OK as soon as I add some 30 weight nondetergent oil. There's no down pressure, but I could add another line and control valve later. Thanks for the responses.
Post A Followup
: Re: Re: saginaw hitch hydraulic lines
