Re: Re: getting discouraged / need help Farmalldan et al
Posted by boog on March 26, 2002 at 07:34:41 from (66.73.130.52):
In Reply to: Re: getting discouraged / need help Farmalldan et al posted by redrev on March 26, 2002 at 05:08:04:
Redrev,
Don't get me wrong, I'm not about to give up. Instead of discouraged I really should have use p-off.
I know the power steering unit works because as I stated I had it working before I put the priority flow control valve in. The only problem was I had to pull both hyd. levers back. Also, I am hooked the same, except now have added the priority valve.
I spent almost 2 years trying to find a bad electrical connection on our 4020 after 3 deere mechanics said they had it fixed. Finally found that ao they shouldn't be as bad.
It's just that some days everything seems to go wrong.
boog
Post A Followup
: Re: Re: Re: getting discouraged / need help Farmalldan et al
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
