Re: Farmall A oil change tips
Posted by big fred on March 26, 2002 at 10:06:34 from (12.13.226.13):
In Reply to: Farmall A oil change tips posted by Tom NY on March 26, 2002 at 08:57:12:
Best thing you can do for yourself is get an operators manual for your A. It will list all the lubrication points on the tractor. If it is a new-to-you tractor, it is a good idea to lubricate all of them, you never know which ones the previous owner neglected or was unaware of. I think I would also change the transmission and final drive oil as well.
There should be an oil pressure gage on the oil filter mounting base. It threads into a 1/4 pipe thread on the aft side of that base. They are readily available from many sources.
Post A Followup
: Re: Re: Farmall A oil change tips
