Re: Wireing problems on Farmall 130
Posted by Bob M on March 26, 2002 at 18:35:50 from (66.66.72.246):
In Reply to: Wireing problems on Farmall 130 posted by Hugh MacKay on March 26, 2002 at 17:47:00:
Sounds like the alternator has failed. Most likely it's internal regulator has a short to ground. Best bet is to simply replace the alternator - a good rebuilt unit is only $35 or so.
No way the stuck ammeter could cause your problem. I would however recommend replacing it anyway simply to tell you whether the charging system is working.
Post A Followup
: Re: Re: Wireing problems on Farmall 130
