Re: Re: rebuilt Farmall A - sounds like a John Deere when throttling up
Posted by lpc on March 26, 2002 at 23:06:17 from (206.102.28.14):
In Reply to: Re: rebuilt Farmall A - sounds like a John Deere when throttling up posted by Hugh MacKay on March 26, 2002 at 13:35:56:
I'd guess you're on the right track, at least with ignition problems. If it's "putting" it says to me that one or more cylinders are dropping out. Most likely way for this to happen is a weak ignition system. Bad cap, bad wires, bad plugs. Remember, don't ever install the plugs wihtout setting the gap. Pretty hard for a carb to drop individual cylinders unless the drop is erratic. You can also hand choke the carb to check for a lean problem while you rev it, if it's too rich you'd probably see black smoke.
Post A Followup
: Re: Re: Re: rebuilt Farmall A - sounds like a John Deere when throttling up
