Re: Re: Re: 856 1st gear doesnt work in all ranges and with T/A back or forward?
Posted by JD Humm on March 27, 2002 at 02:22:57 from (67.202.17.184):
In Reply to: Re: Re: 856 1st gear doesnt work in all ranges and with T/A back or forward? posted by A-man on March 26, 2002 at 16:05:45:
The transmission had to come off the tractor which means a 3 piece split, as for the nut on the shaft it will be obvious once the transmission is removed. I am 99% sure that is going to be the problem, may as well plan on a new shaft and probably a couple of gears, may see more once you get into it. Sorry to bear bad news but have seen this one before.
Post A Followup
: Re: Re: Re: Re: 856 1st gear doesnt work in all ranges and with T/A back or forward?
