IHC Farmall 656 hydraulic lever kicks out when using new loader
Posted by lanny on March 27, 2002 at 19:15:50 from (65.88.144.52):
I just bought a diesel IHC Farmall 656 with a new loader when you put the hydraulic on and use the loader it kicks the hydralic lever out could the loader have air in the lines causing this to happen someone told me that maybe the bypass valve on the loader was set to high and could cause this to happen does anyone know how to bleed a loader or to set the pressure on the loader. the hydraulics make some noise but it was about 25 degrees at the time.... also what do you think the tractor would be worth? it has new goodyear rear tires that are knee deep in rubber and has been repainted.. what do new rear tires cost..? THANKS FOR ALL YOUR HELP AND IDEAS Lanny
Post A Followup
: Re: IHC Farmall 656 hydraulic lever kicks out when using new loader
