Re: Hydro 100
Posted by Honkey on March 28, 2002 at 08:56:35 from (64.68.163.26):
In Reply to: Hydro 100 posted by Peter on March 27, 2002 at 21:52:22:
Hi Peter,
I have a Hydro 100 and I know what you mean. They are a good tractor. I bought one this summer for baling and to run a snowblower in the winter. For a snowblower, they are perfect. You get high RPM's and slow speeds. I haven't had any problems with it.
I will need an injection pump for it sometime in the future, however. The American Bosch pumps on these series of engines D414-436-466 are not the best when it comes to longevity. Usually 4000 hrs. or so before you need a rebuild.
The main thing is to keep you hy-tran and filters changed and be sure to keep the remotes plugged when not in use. Dirt, water and hydro's don't mix!
Good luck!
Matthew in SD
Post A Followup
: Re: Re: Hydro 100
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
