Re: IHC Farmall 656
Posted by RPM on March 28, 2002 at 13:58:27 from (63.110.182.225):
In Reply to: IHC Farmall 656 posted by lanny on March 27, 2002 at 18:49:42:
I will need to know if you have double action cylinders on tractor, or 2 hoses/tips per circuit, as far as bleeding if you cycle (operate) the systems should bleed itself after 1 or 2 times, make sure you have enough Hytran in rear frame, also if 1 circuit is erratic switch tips, sometimes they will lock-up or not pass oil, 06/26/56/ series were prone to this if you didnt match brands of hyd couplers. If tractor is in cold climate check hyd filter for ice or water in Hytran, this will starve pump if present.
Post A Followup
: Re: Re: IHC Farmall 656
