Re: 8 Volt Batteries - Voltage Regualtors - Cutouts - Generators Gremlins
Posted by Bob M on March 28, 2002 at 18:44:44 from (66.66.72.246):
In Reply to: 8 Volt Batteries - Voltage Regualtors - Cutouts - Generators Gremlins posted by BIG JOHN on March 28, 2002 at 14:59:05:
Hey Big John - A few answers to your query: 8 VOLT BATTERYS, ETC: With a cutout-type system, the battery simply charges whenever the generator voltage exceeds 8 volts. This occurs whenever the engine RPM is high enough (typically about 1/2 governer). Downside is if the engine is run at mostly at low RPMs, the battery will never get charged. With a regulator-equipped system, unless the voltage relay is adjusted to begin regulation at about 9-1/2 volts, the battery will charge very slowly - or not at all - on a 6 volt system regardless of RPM. And if the engine is run only at low speeds, the battery will never be recharged even with the regulator reset for 8 volt operation. An 8 volt battery can be recharged with a 12 volt charger - simply wire a 3 amp (at 12 volt) electrical load in series with the charger and the battery. A headlamp works well for this. The lamp will act as a current-limiting ballast to the setup. The brightness of the lamp will also give a rough indication of the state of battery charge - the DIMMER the lamp burns the more fully charged is the battery. 6 volt lamps burned on 8 volts will burn brighter than on 6 volts. But lamp life will shortened, though not drastically. CUTOUTS vs REGULATORS: Cutouts came first - they are simple, cheap and relatively reliable. However charging control is left to the operator (i.e. is generally neglected) so overcharging and ruining the battery is alway possible. Regulators on the other hand provide better control and less chance of overcharging. But regulators cost more and are more complicated (more moving parts), hence can be less reliable. ALTERNATORS - A 12 volt negative ground alternator can be made to supply 6 volts negative ground simply by replacing the internal regulator. There's a few outfits (JC Whitney, others?) that sell these regulators - cost is under $10. However if you want 6 volt POSITIVE ground you must also replace the output diodes inside the alternator. Hope this helps...
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
