Farmall C Timing Gear
Posted by Old Guy on March 28, 2002 at 19:44:35 from (64.12.102.161):
Purchased a non running C. The rotor was not turning (no spark). When I got in to it I found a bad Govenor drive gear. Here is the question - The timing gear has one tooth that is chipped (not broken off just chipped)do you all think I can get away without replacing the timing gear??
It would sure make the fix much easier. I will only use the C for parades and to show, no work.
Any thoughts about if this would be a job for a JB Weld type of product.
Thanks in advance for your thoughts and experiences.
Post A Followup
: Re: Farmall C Timing Gear
