Re: noise in clutch area
Posted by Farmer Bob on March 29, 2002 at 13:57:29 from (66.152.73.108):
In Reply to: noise in clutch area posted by Mark on March 29, 2002 at 13:49:32:
Did you replace the clutch release bearing when you changed the PP/clutch disc? Also could be the fingers on the pressure plate are out of adjustment causing the "Grinding" of gears. Adjust per the manual and also check the pedal freeplay from the edge of the deck to the backside of the clutch pedal arm.//FB
Post A Followup
: Re: Re: noise in clutch area
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
