Re: Plowing with an H?
Posted by shoe on March 29, 2002 at 20:13:09 from (216.83.65.242):
In Reply to: Plowing with an H? posted by Krey in Indiana on March 28, 2002 at 15:46:51:
If it's just garden spots that you are going to plow you need a two bottom three point roll over
two way plow. You have the three point and the hydraulics. For small plots you sure don't want a one way plow. The H will handle 2-16's fairly
good, and will play with 2-14's. In your applica-
tion I think you will be allot happier with a
three point and a roll over.
Post A Followup
: Re: Re: Plowing with an H?
