Re: Farmall A cooling
Posted by John N on March 29, 2002 at 20:36:06 from (150.243.190.75):
In Reply to: Farmall A cooling posted by Mike Scott on March 29, 2002 at 18:21:19:
The A (and many other small older Farmalls) use a thermosyphon system, with no thermostat and no water pump. It generaly works very well and causes no problems -- unless the radiator or the block gets clogged. In colder weather, the engine may actually not warm up enough, unless you restrict air flow through the radiator (older distillate tractors came with shutters). The system is not pressurized, and there is no release. There is an overflow. It's normal to hear the coolant bubbling inside the engine when you shut down a warm engine.
If you use antifreeze/water mix, be sure to mix it outside the radiator, as it won't mix in the radiator.
Post A Followup
: Re: Re: Farmall A cooling
