Thanks! Paul H, FM, The Red
Posted by REA on March 30, 2002 at 05:51:57 from (66.119.34.39):
Hi, I did what you men said and found the problem. I changed the oil because of gas smell, then checked out the hydraulic pump, and found the nut had backed off and hiting on casting. How do I keep it from backing off again? I had it secured by bending that lock washer. Thanks again.
Bob
Post A Followup
: Re: Thanks! Paul H, FM, The Red
