Re: Reduce 60L plow to 2-bottom?
Posted by Hugh MacKay on March 26, 2009 at 14:02:21 from (209.226.106.143):
In Reply to: Re: Reduce 60L plow to 2-bottom? posted by mkirsch on March 26, 2009 at 10:47:57:
MKirsch: Did you check to see if those front wheels can be moved forward. I'd be surprised if those beams aren't drilled for mounting the wheel rockshafts in the forward position. If you had a manual to go by the hydraulic lift would only require minamum fabrication for change.
