Farmall Tractors Discussion Board
Re: Runaway Torque
Posted by RickB. on August 04, 1999 at 17:34:59 from (205.231.28.88):
In Reply to: Runaway Torque posted by LittleRedHen on August 03, 1999 at 23:08:39:
Mechanical TA's all over-ran in TA. Every one. This covers all tractors prior to 706-806 tractors that all had hydraulic TA's (if they had one, some had no TA at all). After 1963, small frame tractors such as the 504, 544, 656, 606 still used the mechanical TA. I believe this category would also include the 666 and 686 models, but I may be wrong. Hydraulic TA's have a multiple disc wet clutch to drive in direct, as opposed to the 7" dry single disc clutch in mech. units. Hyd units also have a similar wet clutch with less discs on the TA side that prevent the tractor from freewheeling like a mechanical unit does.
Post a Followup
: Re: Re: Runaway Torque
