Pre-Flight Check... Cont.
Posted by Brian on March 30, 2002 at 16:35:55 from (66.185.84.197):
Still working on getting the Old A that has been stored for 10 years ready to go. Changed oil & Filter. Pulled off Valve Covers to make sure the valves were free ( all were but one, which needed a little gentle tap ). Gonna Drain and clean the gas tank and carbs. Going to Replace Coolent. Going to fill fan belt pulley assembly with oil. Will replace Gear lube in trans. Further Suggestions ? How about oiling the bearing on the generator ? Should I be worried about any of the Inner oil channels or ducts ? I just found out that the clutch pedal and the brake pedal beside it appear to be locked together. Any suggestions ? And finally..... I know that there is liquid in the tires, and I've read that is causes rust. Soo.... is there any way to neutralize it ? Is there a better liquid to use now ? Should I try to sand off the rust ? I'm afraid I'll just sand away the whole rim ! Thanks Boys...
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
