Re: Crankshaft Pully - C113 Engine
Posted by Farmall Gray on March 30, 2002 at 18:11:26 from (205.188.197.177):
In Reply to: Crankshaft Pully - C113 Engine posted by OLD GUY on March 29, 2002 at 15:11:51:
Those collars are called bearing splitters. They
are the best way to get the pulley off without breaking it. If you just use a 2 or 3 jaw puller,
you are pulling on a very weak part of the pulley.
That is why these pulleys are readily available from the aftermarket-lots of them get broken.
Post A Followup
: Re: Re: Crankshaft Pully - C113 Engine
