Re: Help needed with McCormick No.60 3 bottom, 1st timers
Posted by Hugh MacKay on March 30, 2002 at 20:51:35 from (209.226.247.15):
In Reply to: Help needed with McCormick No.60 3 bottom, 1st timers posted by mike on March 30, 2002 at 17:53:10:
Just got out manual for No.60 plow. There are a couple different set ups for hydraulics on this plow. From the picture you first posted, cylinder goes from bracket at top left to hole on flat plate bottom right of your picture. That flat plate must be welded to axel shaft, can't tell by your picture or mine. I would say yours is all there. My plow has the different hydraulic set up I mentioned earlier. 3" bore cylinder should lift this plow. The plow requires an adjustable stroke cylinder as that is what controls depth.
Post A Followup
: Re: Re: Help needed with McCormick No.60 3 bottom, 1st timers
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
