Re: Question for Bob M.
Posted by Bob M on March 31, 2002 at 20:23:10 from (66.66.72.246):
In Reply to: Question for Bob M. posted by Andrew on March 31, 2002 at 19:30:15:
Andrew - The 1-wire alternator uses a different regulator from the standard 3-wire unit. I don't know all the internal details, but works by maintaining a very small, but constant current drain thru the BAT terminal.
The 1-wire units are simple to wire up but have a couple of inherent disadvantages: 1 - The constant current drain will pull the battery down if left connected and the engine is not started for an extended period (generally a few weeks). 2 - The 1-wire unit must be spun up to a higher RPM than a 3-wire to "turn on" the regulator and commence charging at startup. (Once it begins charging it will continue to charge when idled down, same as for a 3-wire.)
Hope this helps...
Post A Followup
: Re: Re: Question for Bob M.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
