Re: Cub 184 Clutch removal
Posted by Dale on April 01, 2002 at 21:53:27 from (12.93.73.44):
In Reply to: Cub 184 Clutch removal posted by Bama Binder on April 01, 2002 at 12:49:09:
before you take anythimg apart try this.Check to see that your release bearing fork is depressing your pressure plate right,then with clutch pedel in push or drive a gasket scraper between the clutch and pressure plate.Sometimes you can drive it with pedal in up some hills and they will come loose on there own.Also if clutch is loose a bad pilot bearing will act the same way.
Post A Followup
: Re: Re: Cub 184 Clutch removal
