Re: 966 shifting problems
Posted by Honkey on April 02, 2002 at 09:24:39 from (64.68.163.40):
In Reply to: 966 shifting problems posted by wade on April 02, 2002 at 03:57:21:
Hi Wade,
The binding could be caused by a bad pilot bearing. Or maybe the dump valve and trans brake need adjusting.
When you go to look at it, push the clutch in hold it in and count to 15. Then try to shift into gear, if it grinds or binds, chances are it's the pilot bearing rather than a misadjustment.
Good luck,
Matthew in SD
Post A Followup
: Re: Re: 966 shifting problems
