Farmall Tractors Discussion Board
Re: Re: Re: Re: fluids and lube for H
Posted by The Red on August 05, 1999 at 03:16:05 from (12.75.196.86):
In Reply to: Re: Re: Re: fluids and lube for H posted by Wayne on August 05, 1999 at 02:52:08:
90W or 85w-140 for the rear end. 6 gallons.
SAE 30 detergent for the engine and 6 quarts.
For grease I am using the new red silicon water resistance stuff that NAPA sells.
Oh and also SAE 30 for the oil bath air cleaner. Not quite a quart. There is a fill line on it.
For the liftall, 6 quarts of NON-DETERGENT SAE 30. You can use detergent but it bubbles on you a tad. Or you can use a good hydraulic oil. They were not common back when the H was being produced. It will take more oil if you have an attachment of some sort.
For the cooling system, 4 1/4 gallons. I recommend 2 quarts of whatever antifreeze you like.
Windex on the windshield. :)
Post a Followup
: Re: Re: Re: Re: Re: fluids and lube for H
