Re: Lights on a 300U
Posted by Bob M on April 02, 2002 at 18:10:25 from (66.66.72.246):
In Reply to: Lights on a 300U posted by Randy on April 02, 2002 at 10:22:07:
RAndy - A quick course in light wiring:
Power supply - If you want the ammeter to read correctly, tap from the ammeter post that connects to the voltage regulator - NOT from the post that goes to the battery. (Can also tap from the BAT terminal at the voltage regulator if this is easier to get at than the ammeter).
Grounding - Ground one wire (either one) from each light assembly to any metal on the tractor.
Switch - Locate this between the power supply tap and the lights. Good idea to install an inline fuse holder and fuse (15 to 20 amps is good) ahead of the light switch. Will save the wiring if you make a wiring mistake!
Good luck!
Post A Followup
: Re: Re: Lights on a 300U
