Re: Repowering H with 4 cylinder diesel?
Posted by Jim in Wisc... on April 02, 2002 at 18:37:36 from (209.240.222.132):
In Reply to: Repowering H with 4 cylinder diesel? posted by jmyt_47 on April 02, 2002 at 11:36:50:
I put a the diesel engine from the 350u in my "H" when I blew the motor back in "92".( it's the continental diesel engine ))...fits in perfect except you have to weld in a fuel return in the fuel tank....and have live hyd..cause the diesel has pump ahead of injector pump so I have the belly pump and also two way hyd. with live pump....makes the "H" as powerful as an "M" and three times handyer cause of it's size....plus I went a couple steps farther and put front hubs from a 460 so I use same wheels as on hay wagon and put the rear cast centers on also so I use the larger/newer style wheels...like in the spring I put a set of 18.4 x 38's on ....can float over any field ......good luck in your search...
Post A Followup
: Re: Re: Repowering H with 4 cylinder diesel?
