Re: Exhaust pipe for 1950 H
Posted by Michael Soldan on April 02, 2002 at 21:24:52 from (216.46.130.11):
In Reply to: Exhaust pipe for 1950 H posted by Grant on April 02, 2002 at 11:53:33:
Boys you can tune your exhaust system to scavenge and get the most power out of your machine. Put in a 3-4' piece of pipe and run the tractor under load. You will see the heat mark on the pipe where it appears to have gotten the hottest. That's where the scavenging is taking place and its there that you should cut the pipe. You will now have a tuned exhaust giving you maximum horse power. With tractors its easy..in autos Hedman, Hooker,and supply co.s such as these have done the tuning. Auto racers have been using tuned exhausts for decades...Good luck from Mike in Exeter Ontario
Post A Followup
: Re: Re: Exhaust pipe for 1950 H
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
