Re: Char-Lynn SMTA leak
Posted by Bob M on April 03, 2002 at 06:57:20 from (165.170.128.66):
In Reply to: Char-Lynn SMTA leak posted by Dick Davis on April 03, 2002 at 04:22:12:
Dick - Before you start messing with the PS unit itself, check hydraulic manifold on the side of the PS unit. The Charlynn was leaking pretty bad when I got my SM. Turned out the two allen head screws that clamp the manifold to the PS unit were slightly loose. A half turn on each screw stopped the leak.
Could also be the O-ring seals under the manifold need to be replaced.
Post A Followup
: Re: Re: Char-Lynn SMTA leak
