Re: Shop time/cost to overhaul MTA's TA?
Posted by John In Iowa on April 03, 2002 at 07:38:50 from (199.108.164.36):
In Reply to: Shop time/cost to overhaul MTA's TA? posted by Al on April 02, 2002 at 18:36:24:
Get your checkbook out. While you are there you may as well do both clutches and have the flywheels ground. New bearings in both clutches and doesn’t forget the pilot bearing. Its takes a lot of work to get there so you may as well fix everything while you are there. May save you a big headache down the road.
John In Iowa
Post A Followup
: Re: Re: Shop time/cost to overhaul MTA's TA?
