Re: H going uphill???
Posted by Bama Binder on April 03, 2002 at 13:08:31 from (199.97.118.200):
In Reply to: H going uphill??? posted by Charlie in Cincinnati on April 03, 2002 at 10:00:08:
I don't know about an H, but I have taken a Cub up a 35 degree concrete drive. It felt strange but I did it dozens of times, once in the rain.
Was it safe? Looking back it was absolutely insane. I think one of the problems you run into is traction or what happens when you are loaded and you have a large difference in the amount of traction from one side to the other. Bad things happen when that occurs.
Pulling something only makes things worse. whatever you do, I would go slow and be ready to get off the clutch and on the brakes if your front comes up or you can't steer.
I'm not real sure I would lock the brakes...it might end up being your only steering. I don't know...
Post A Followup
: Re: Re: H going uphill???
